I found a new instant messenger on www.my-symbian.com
It's name is 12planet IM, it supports MSN! Didn't try it, but will do so in a very short time 😃
Well, I tried it a little. It's MSN only (which is fine for me, since I only use MSN). I think it's way better than TipicME. There only is one huge disadvantage. When you get a message you won't get ANY form of notification! Hopefully they change this VERY soon. But besides that drawback it's a perfect program!
Tipicme is free right? 12 planet aint 😞
12 Planet has 2 version: A Lite and a Pro....... Lite is free
This is a great app for the P800 and is much easier to use than TipicME. Just like the MSN Messenger on your PC.
Download it at http://www.12planet.com/en/software/symbian/im.zip
Whats the difference between full version and lite? 😊
@distracted: Is that the liter version? I went to their site but cant find the page about symbian 😞
Muzikfreakah: The version i downloaded is the lite one. It does not seem to be crippled as often is the case with lite versions of software.
http://www.12planet.com/en/software/index.html has a link on the right hand side which says something like IM Client for Symbian. 😊
...or try my-symbian.com
Wow! 😊 This ap is awesome!! 😊 Will this work with the 3650 as well? 😊 😊 Me and my GF cansave a lot of money with this!! 😊 Hope it works with the 3650 😊
