quick question,
if I purchased a new unlocked 3650 from Nokia store today would it be able to record sound with video?
3650 sound with video?
The one I bought yesterday did - the updated cam software was pre-installed on the MMC.
And there was a note inside advising me NOT to delete it 😊
So I guess it depends on how long the shop has had it on their shelves. If not it's only a small file to download and intall 😊
Best
Will
was yours new from a shop? I dont think a MMC will be included from the store, is it true then that if I purchased a 3650 with the very latest firmwear (which is??) then it will be able to record sound with video? if not,
you say it can be downloaded can it be downloaded direct to the handset via gprs wap? thanks in advance.
Yes - from a shop.
They come with a 16mb MMC in the package 😊
Not sure if Nokia have a wap site for downloading updates, but I can always put it up on my WAP site for you to download.
Best 😊
Will
I would like that update too 😊
will i went to t mobile shop today and one of them said they dont tihnk a 16mb card comes wiv it.................
Hi please can you direct me to somewhere where I can download the program that enables me to record voice with my video? I have just purchased a new 3650 today it is on charge now.
thanks
Liam
hi,
u dont want the app. because if u install it, u can only record 9 seconds. without sound u can record to 21 seconds
cya amigappc
if i install the app cant i chosse on a case or case basis wether i want to use the sound for 9 sec or turn sound off and get the full 21secs?
is tht also the case wiv the nokia update?
what exactly is the nokia update and where can I get it from? does it allow full sound with video?
Yes, it allows sound + video. Available at http://www.nokia.com/phones/3650/support
Although I recommend HipCam (available from http://www.handango.com/ , $19.99 ) becuase you can record up to a few minutes.
does the updated software not come wih new 3650s already?
Hipman can you place the nokia update on a wap site to download via gprs direct please ...
I meant would it be possible for you WillBrady to host that for me?
Id be very grateful.
I could host myself but cant get the proper file out of the .sis extension. the raw file to put on the site?
You should be able to get it here
http://nds1.nokia.com/phones/files/software/Nokia_3650_Videorecorder.SIS
Also the guy in the T-Mobile shop is talking out his ar#e.
The phone comes with 16mb MMC - if it does not then don't buy it as someone has knicked it 😉
Will
