http://www.esend.com/sandisk/product.asp?sku=SDSDB%2D64%2D781&mscssid=WMQHXSU5V94C8N0KD0DKHCSW9VMF7X28
I have bought this one at the same place i bought the phone, and they sad it should work, anyone know for sure?
// Stoffe
// Stoffe
SD (Secure Digital) Cards do NOT work, you only have to read others posts in the forum to know this.
The only cards that work are MMC (MultiMedia Cards). At the same site they are @ http://www.esend.com/sandisk/products.asp?value=MEMM&valueIs=dept&mscssid=WMQHXSU5V94C8N0KD0DKHCSW9VMF7X28
if they told u it'll work maybe its an MMC.. if not just return it to them and say they buggered u.
MMC works in SD slots not vice versa
the reason why SD wont work in the 3650 is because its a thicker card, therefore it wont fit in the slot in the 3650.
Yes, an SD card is slightly thicker than MMC, but size is not what it really is about; SD has different connectors (more leads) & electronics (however, as mentioned, SD card readers are backwards compatible with MMC and can thus still read MMC cards).
yea, but for those who dont know, its easier to explain than leads and connectors and stuff... :P 😃
i agree it wont work 2 big!
