New FileExplorer 1.08
17 replies · 3,722 views · Started 07 April 2003
😮ops: Oops ...
In the previous version posted last week, the 'phone information' doesn't display the phone information anymore !!, therefore, I re-post a new version today 😃 - by the way, I have added a new menu option : 'network information' which gives the code and network name currently used (let me know if it runs on all network).
I have also changed the scaling method for resizing a picture file to be set as operator logo.
The editor is now functionnal, you can even edit an .app file !! (the non-displayable characters are replaced with a '?' )
Hope you enjoy 😉 .
Sorry for the trouble,
Domi.
hi domi , i'm try using yur fexplorer v1.08b to set operator logo. it said logo has been set but it do not reboot. i using v4.46 and a 7kb jpg image . can u pls teach mi how to set that ops logo
thanx again domi, great work.
the 'network information' work fine (germany, o2)
but the oplogo doent vchange 😞
i know how to do it, but the fexplorer wont change it the right way.. he generates the image with the right name but with the extension xxx.bmp.. my old logo xxx.mbm stays in the folder, so it wont change..
thought you might want to know it...
but i like your "baby" very much..
greetings tias
keep the fexplorer free.. tell me if i can help keeping it freeware
[quote="tias"]i know how to do it, but the fexplorer wont change it the right way.. he generates the image with the right name but with the extension xxx.bmp.. my old logo xxx.mbm stays in the folder, so it wont change...[/quote]
Thats because it can be bmp or mbm, both work fine. But phone prefers mbm. Just delete the mbm version from the folder.
That way the next time you change it, it overwrites the old bmp version.
Great work Domi! This is without a doubt the best file viewer/browser etc etc for the 7650.
Keep it up! It's much appreciated!
Thanks to all of you !!
Tias, hope your problem is solved ...
As Jyrik has notified, the best way is to place a bmp file (not a mbm) !!
just one remark, if you try to set a jpg or a gif, it's automatically re-scaled to fit the size of the op-logo (97 x 25 pixels) but any bmp file aren't !!! I don't know if you prefer to re-scale the bmp too -- it's a poll !!!
Stormuk, I'm working to something to compress files, but I have not yet found the best process (i.e. small -!!-)
Domi.
[quote="JyriK"]
That way the next time you change it, it overwrites the old bmp version.[/quote]
thanx 😊 i knew that one, but wanted to point out that it might not work on phones that already have an operatorlogo.. cause most operatorlogos have the mbm extension, and then the fexporer cant change it 😉
but anyway, great work domi 😉
Your welcome ...
By the way, I need a little bit of help, Tias, to translate the remaining texts in german ... could you do it ??
thanks in advance,
Domi.
hi guest..
why dont you make another icon, and if domi likes it, maybe he will change it?!?!? 😉
: P,
I like my icon but I want (I try...) to follow any request of the users, so I propose that any users who have some nice icons (not captured from the windows OS please ..) post them in this forum and we can choose one !!!
OK ??
I'm waiting ....
Domi.
Domi,
I don't suppose you could tell me how to ues the ScreenShot application in Fexplorer?
Bob
