just wonderin' if anyone tried app from psiloc... does it work better with 3650? coz they said that it has bugs when installed with 7650..
anyone tried irRemote with 3650
I installed irremote and it doesn't work!
the final (ie Non-beta) version works great on 3650. kinda odd holding the phone on its left though.
Yeah, bit awkward to use as the phones IR-Port is on the side of the phone and not the top.
And so far for what I've seen the signal is not strong enough to let you bounce it off the wall and you have to line it up pretty precisly with the device your trying to control.
Still a great APP for showing off your phone!! 😊
Best 😊
Will
but mine is working fine,currently using 0.93 irRemote,no probs at all 😊
Hello,
I'm very anxious about the Ir remote capability in 3650
Where can I download the final version for free?
Thanks :P :P :P
^ that is illegal 8)
.. but there are sites which have it. Don't as me where though.
WARNING: irRemote can down 3650. after restart phone doestn boot !!!!!!
it fix only flash new FW
I have instaled and it works fine!
yes but some FW version + some version of irRemote is not good.
program replace original .dll and phone doestn boot 😞
IR Remote works fine for me. PsiLoc said that they were incorporating a 3650-friendly map for the remotes so we can hold it horizontally~!
I'm currently using IR Remote 0.91. It works fine.. Maybe the 0.93 is not stable yet... Just uninstall the the 0.93 and get the 0.91.. :angel: :angel: :angel: :angel: :angel: :angel: :angel: :angel:
[quote="Seremify"]IR Remote works fine for me. PsiLoc said that they were incorporating a 3650-friendly map for the remotes so we can hold it horizontally~![/quote]
Yeah, works fine for me too. Around 18 ft away from my DVD player inside my room.
Though it didn't work for the other devices. PsiLoc says they will constantly update their database of devices. I just wished they have the "learning" capability so i wouldn't have to wait, just like OmniRemote for the Palm OS.
