hi everyone
i wanna to ask about one thing .......
i want to make a program for auto answer .. i mean you give a list of number or contact name to the program ,,, when someone called to you and his name on the list the phone will answer automatically ...
so i know Java ... but i don't know how to start it ...
Very thank you for your message, I think samsung mobile phone shell or very good has distinguishing feature very much, and can better prevent fingerprints and dust effect is a very good accessories
http://www.bestsamsunggalaxys3case.com/kalaideng-cross-grain-red-silicone-shell-for-samsung-galaxy-s3-28706.htm
Very thank you for your information, look forward to your update again ah
I want to suggest you that you need to take advice for that an expert developer because he will pertain you for your programme. Basically, you want to built an application like this which helps people to answer automatically. Your idea seems quite interesting and for that a web developer will help you to do that.
The battery life depends on the number of repeatedly charging and discharging, so should try to avoid more charge when the battery power, this will shorten the service life of the battery. Mobile phone off time more than 7 days, should first will phone the battery to completely discharge, enough electricity before use.
