Today my hardware stopped when 658M,60% percent. I tried to fix it for several times, but I failed.
Nokia and PC doesn't match any more? need help in a hurry, thanks a lot
My "Nokia Care Suite" upgrade doesn't work. normal?
The battery life depends on the number of repeatedly charging and discharging, so should try to avoid more charge when the battery power, this will shorten the service life of the battery. Mobile phone off time more than 7 days, should first will phone the battery to completely discharge, enough electricity before use.
I think you should remove your Nokia Care suite and try to reinstall it again 100%. This time make sure that not to fail again. After installation process open PC suite location and connect with your phone and it might be run correctly now.
