Hi
I am about to get an XDA type device to trial and want to know the easiest way to transfer my phone book to this phone.
I have copied the contacts.cdb using flight mode, but will I be able to import this onto the XDA?
KB
Hi
KB
Short answer: no. 😞
Very unlikely, your best bet is if the XDA synchronises with Outlook (as it is MS based I imagine it can), then first sync your 7650 with Outlook contacts through PC Suite. Next sync the XDA with Outlook through whatever software comes with the phone.
bob
[quote="KevB"]Hi
KB[/quote]
No it is not compatible. You can use synchronization - or export it to XDA using Contacts Manager into csv/txt file.
http://www.communicator.cz/agora/agora.nsf/0/EEFD708566D50DEAC1256CEE005AAF27
