I know Lotus Notes 6 is rather new and SonyEricsson hasn't yet released any Sync software for it.
I am sure that if "Billy Gee" had thrown a New version of Outlook to the market our Swe/Jap friends would have responded much faster with a sync solution.
Bad service SonyEricsson &
Weak pushing IBM
Does anybody know of a way to sync the P800 with Notes 6?
All tips are welcome.
So far, there are a couple of work arounds to sync with Notes 6. There is a registry hack that fools the P800 sync software into seeing a Notes 5 installation and it will use the Notes 6 databases. Unfortunately, in my case, Contacts and To Do's sync fine but Calendar will not. Here is a link to the hack:
http://www-10.lotus.com/ldd/nd6forum.nsf/DateAllThreadedweb/95629f3e193f009b85256cc6005aa8d8?OpenDocument
I can also sync Notes 6 with Lotus Organizer 6 using Extended Systems XTndConnectPC. The P800 sync software recognizes Lotus Organizer and the sync with the P800 works well.
Please post if you find a better way.
Martin
