Symbian website listings
13 replies · 77 views · Started 07 April 2003
Currently working (Hereby refered to as Slacking) on a Symbian website listings site, still quite (read Extremely basic) at the moment. But it works fine, just needs making pretty.
If you have any websites (Symbian/Smartphone based) if you wouldn't mind taking a few mins to add them to the database.
I will create a universal Admin login so it will be easier soon and post the details in here.
Links can be added by clicking here
Nice idea 😃
Looking good so far.
The voting system should use cookies, so cant vote more that once for
same link.
Yo brothers, i just install the phpBB in my server, i have some little problem in setting it up. It say i need to install it, DSN, database, password, bah bah... do you have any example of the setting config on windows platform? 😞
You need to input the name of your MySQL database, username and password
Database name will look something like this: symbian_world_1
Localhost will sometimes work too 😉
Here is mine 😃
$db_host = "localhost"; // Your mySQL server host address
$db_name = "symbian-world_com_1"; // The name of the database to use
$db_user = "[email protected]"; // Your mySQL username
$db_pass = "******"; // Your mySQL password
Warning: mysql_connect() [function.mysql-connect]: Unknown MySQL Server Host 'mofhq122/forum' (10110) in D:\wwwroot\phpBB2\db\mysql4.php on line 48
Warning: mysql_error(): supplied argument is not a valid MySQL-Link resource in D:\wwwroot\phpBB2\db\mysql4.php on line 330
Warning: mysql_errno(): supplied argument is not a valid MySQL-Link resource in D:\wwwroot\phpBB2\db\mysql4.php on line 331
phpBB : Critical Error
Could not connect to the database
WTF????
YES!!! version 4
Data directory is in d:\data\
Server runnining in c:\mysql\bin\
I really have no ideal what happen, in asp, i just need to connect via DSN connection with ODBC or a DSNless connection. This one i have problem coz i am new to php files....
Tell me about it! My MSc Final Project was "ASP vs PHP in respect to database connections". ASP is very easy but PHP is faster because it is more direct.
Anyways, how does your configuration file look like?
See Jordans example and show us yours!
I will post the script here when i get to office tomorrow... took a day off to settle my phone problem with my ventor
[quote="Edgedale"]Warning: mysql_connect() [function.mysql-connect]: Unknown MySQL Server Host 'mofhq122/forum' (10110) in D:\wwwroot\phpBB2\db\mysql4.php on line 48
WTF????[/quote]
Are you sure that is the correct host?
Unless you have a nice DNS set up that sounds strange.
telnet to it dos command: telnet mofhq122/forum 10110
Maybe download a simple sql client to test....
<?php
* mysql4.php
* begin : Saturday, Feb 13, 2001
* copyright : (C) 2001 The phpBB Group
* email : supportphpbb.com
* $Id: mysql4.php,v 1.5 2002/04/02 21:13:47 the_systech Exp $
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
if(!defined("SQL_LAYER"😉)
define("SQL_LAYER","mysql4"😉;
class sql_db
var $db_connect_id;
var $query_result;
var $row = array();
var $rowset = array();
var $num_queries = 0;
var $in_transaction = 0;
// Constructor
function sql_db($sqlserver, $sqluser, $sqlpassword, $database, $persistency = true)
$this->persistency = $persistency;
$this->user = $sqluser;
$this->password = $sqlpassword;
$this->server = $sqlserver;
$this->dbname = $database;
$this->db_connect_id = ($this->persistency) ? mysql_pconnect($this->server, $this->user, $this->password) : mysql_connect($this->server, $this->user, $this->password);
if( $this->db_connect_id )
if( $database != "" )
$dbselect = mysql_select_db($this->dbname);
if( !$dbselect )
mysql_close($this->db_connect_id);
$this->db_connect_id = $dbselect;
return $this->db_connect_id;
else
return false;
// Other base methods
function sql_close()
// Commit any remaining transactions
if( $this->in_transaction )
mysql_query("COMMIT", $this->db_connect_id);
return mysql_close($this->db_connect_id);
else
return false;
// Base query method
function sql_query($query = "", $transaction = FALSE)
// Remove any pre-existing queries
unset($this->query_result);
if( $query != "" )
$this->num_queries++;
if( $transaction == BEGIN_TRANSACTION && !$this->in_transaction )
$result = mysql_query("BEGIN", $this->db_connect_id);
if(!$result)
return false;
$this->in_transaction = TRUE;
$this->query_result = mysql_query($query, $this->db_connect_id);
else
if( $transaction == END_TRANSACTION && $this->in_transaction )
$result = mysql_query("COMMIT", $this->db_connect_id);
if( $this->query_result )
unset($this->row[$this->query_result]);
unset($this->rowset[$this->query_result]);
$this->in_transaction = FALSE;
if ( !mysql_query("COMMIT", $this->db_connect_id) )
mysql_query("ROLLBACK", $this->db_connect_id);
return false;
return $this->query_result;
else
return false;
// Other query methods
function sql_numrows($query_id = 0)
if( !$query_id )
$query_id = $this->query_result;
return ( $query_id ) ? mysql_num_rows($query_id) : false;
function sql_affectedrows()
return ( $this->db_connect_id ) ? mysql_affected_rows($this->db_connect_id) : false;
function sql_numfields($query_id = 0)
if( !$query_id )
return ( $query_id ) ? mysql_num_fields($query_id) : false;
function sql_fieldname($offset, $query_id = 0)
if( !$query_id )
return ( $query_id ) ? mysql_field_name($query_id, $offset) : false;
function sql_fieldtype($offset, $query_id = 0)
if( !$query_id )
return ( $query_id ) ? mysql_field_type($query_id, $offset) : false;
function sql_fetchrow($query_id = 0)
if( !$query_id )
if( $query_id )
$this->row[$query_id] = mysql_fetch_array($query_id, MYSQL_ASSOC);
return $this->row[$query_id];
else
return false;
function sql_fetchrowset($query_id = 0)
if( !$query_id )
if( $query_id )
unset($this->rowset[$query_id]);
unset($this->row[$query_id]);
while($this->rowset[$query_id] = mysql_fetch_array($query_id, MYSQL_ASSOC))
$result[] = $this->rowset[$query_id];
return $result;
else
return false;
function sql_fetchfield($field, $rownum = -1, $query_id = 0)
if( !$query_id )
if( $query_id )
if( $rownum > -1 )
$result = mysql_result($query_id, $rownum, $field);
else
if( empty($this->row[$query_id]) && empty($this->rowset[$query_id]) )
if( $this->sql_fetchrow() )
$result = $this->row[$query_id][$field];
else
if( $this->rowset[$query_id] )
$result = $this->rowset[$query_id][$field];
else if( $this->row[$query_id] )
return $result;
else
return false;
function sql_rowseek($rownum, $query_id = 0)
if( !$query_id )
return ( $query_id ) ? mysql_data_seek($query_id, $rownum) : false;
function sql_nextid()
return ( $this->db_connect_id ) ? mysql_insert_id($this->db_connect_id) : false;
function sql_freeresult($query_id = 0)
if( !$query_id )
if ( $query_id )
mysql_free_result($query_id);
return true;
else
return false;
function sql_error()
$result['message'] = mysql_error($this->db_connect_id);
$result['code'] = mysql_errno($this->db_connect_id);
return $result;
} // class sql_db
} // if ... define
