New: SicBO - Dice Game for Series 60
1 replies · 2,698 views · Started 07 April 2003
SicBo is a popular Asian Dice Game that is found in casino's around the world. Now you can play it on your Series 60 device without losing an arm or a leg in money. The software can be purchased from Handango and more information if available from the author's website.
Author Notes:
SicBo is one of the most popular dice games in Asian. SicBo can be found in the casinos of Las Vegas and Atlantic City as well. The basis of this game is very simple. You bet on the outcome of three rolled dice. The table consists of areas where you can place your bet on the outcome of the dice. SicBo is very similar to a popular English game known as Grand Hazard. You'll see that the game is also similar to Big Six in the manner of placing the bets and the odds. In Chinese, sic bo literally means "dice pairs". Press the '1', '2' or '3' numeric keys to set your bet ($10, $25 or $100 respectively). The maximum possible bet is $100. To place a bet, move the small hand using your navigation keys and press the numeric key correspondant with the bet you want to set ('1', '2' or '3'😉. Press the fire key to throw the cubes. This game allows the following types of bets:
Single Number Bets. In this row you bet on the numbers that the cubes show after you roll them. If one of the three cubes shows the number you bet on, you win and get paid a 1:1 odd. If two - 2:1 odds and if three - 3:1.
Two Number Combinations. The odds here are 5:1. This combination bet consists of placing a wager on any two cubes combinations.
Three Number Totals. In the three number total you bet on the combined result of the cubes roll. A result of three and eighteen will always mean a loss for you. Different results offer different odds.
Small or Big Wager. In this kind of bet you bet on whether the combined result of the roll will be either between Four and Ten (small wager) or between Eleven and Seventeen (big wager). The odds on this bet are always 1:1. If the result of the cubes roll is a triplet, both of the wagers loose.
Triple and Pair Bets. Betting on a single triplet will give you the highest odds in this game. You can also bet on all six possible triplets at once, this is called any triplet. Or you can bet on a pair, which is obviously two cubes of the same number.
For further assistance, please visit at www.jacado.com or email us at [email protected].
sounds great... unfortunately i don't know how to play and don't like to pay to learn.
as a note though; if someone were to make a Big 2 app... then that'd be totally kickass if it supported bluetooth multiplayer.
