MMS setting problem
3 replies · 2,891 views · Started 08 April 2003
I just upgrade my phone from 2.41 to 2.50 and having problem with the MMS setting.
With 2.41, what I did was I just went to Messaging and set the MMS by chosing the preferred connection. After that, it never asked me if I wanted to define the MMS setting again or not.
But after upgrading it to 2.50, it always asked me if I wanted to define the MMS access point even though I did define the access point.
What is wrong with it?
Can someone help me out?
Try deleting your MMS connection setting at Tools>Settings>connection
then enter again or request the connection setting again from your local network provider, save as default
:angel:
Nokia can send you the connection settings to, goto www.nokia.co.uk and use their configurator wizard.
Will
