Unable to write characters/sms
9 replies · 3,234 views · Started 08 April 2003
hi,
i have a problem with my phone. I turned it on today and on starting up..i got an error (don"t know which one exactly) and it says that i should contact my phone dealer. So i turned it off and on again. Now it started up correctly. The problem is now that i can't write any characters. If I want to type a sms i can only type numbers (i cant switch with the pencil or #-Button)..same with contacts..can't write any characters there in the name field e.g., there just appear numbers...and i also have a dictionary on the phone but i can't write chararacters there also... 😞
What now ???
Have you just installed wildskins?
You have uninstalled it - without deactivating it.
Re-install it.
activate it
reboot
deactivate it
reboot
check it REALLY is deactivated
uninstall it
reboot
You should be back in business.
Will
Thanks..it worked..i didn't have to go throught the whole (re)installation procedure..turning them off and rebooting the phone was enough to bring it back to work
thx
Ahh you still had it installed - that was easy for you then 😉
Most people have already uninstalled it before seeing the problems, then can't understand if it has been uninstalled why it should still cause them problems 😊
Glad it worked for you 😊
Will
willbrady,
I could have saved much time if I see your post on this one.
I had to reinstall my phone because of wildskinz.
well I guess I know how to fix it now.
that proggy is not good.
stay away from it...
Geez Already uninstall the wildskin but it's still not work out.
And i already reboot too..... 😞
[quote="Nokia3650"]So it's "dangerous" for me to deinstall the wildskins now ??[/quote]
As long as it's deactivated it can be saftly un-installed.
PS. This info is all over these forums on different threads, you guys really should search before reformating your phones 😉
Best 😊
Will
guys....
i am having a Nokia 3230 and i a have the same problem....unable to type any characters....in contacts and sms.....help me out..............
