Hi guys, I've seen a lot of you posting messages saying you are having trouble with O2 and Oplayo.
I mailed my contact at Oplayo - here is the respone.
I hope it helps you guys 😊
Will.
I noticed our settings listed on our site had a typo on the O2 settings,
so that might have been the source of the errors.
If the connections have worked before, the reason for the problems might
have been that the O2 is now more strict about the correct settings.
They do offer the Internet connectivity and now have a guide on how to
create a connection for the 7650/3650 e-mail client. The same settings should
also work for the Oplayer. Do note that you need to have the O2 Mobile
Web service activated in order to use the connection. The guide is
available at:
http://www.o2.co.uk/productsservices/mobileweb/pdfs/7650%20email%20set%20up.pdf
Best Regards,
