how the F do u delete downld'd ringtones?!
5 replies · 2,252 views · Started 08 April 2003
k ive downloaded a cpl of crap ringtones and they kind of installed to the list of tones but theyre not in the sounds folder etc..... so hoe the F do i delete them??????
in the infamous words...........
ITS A GOOD ANSWER BUT ITS NOT QUITE RIGHT!
heheh
no it is and cheers i didnt know that, but i also downlaoded sum crappy kngiht rider and pink panther tones and thyre now in my tones list but not in extras>recorder or in the sounds folder on the MMC!??!?!
really confusin me and actually startin to P me off!
they are saved in MMC? if yes, use file manager like seleQ or FExplorer to find *.wav or *.mid then delete the ones u want to get rid
:angel:
I forget to write or did I explained properly? LOL
Use the "Find" function of any File Manager that you have and enter *.wav or *.mid on drive C: or E:
