can u change the ALARM RING???
3 replies · 2,148 views · Started 08 April 2003
any1 know if or how you can customise the alram ring tone to what u like i knwo you can do this on certainother phones and maybe even earlier nokias...........
Use Smartprofiles from www.symbianware.com or eProfiles from www.psiloc.com
You can change the alarm and calendar tones
SmartProfile does not have vibrator support. Even if you had turned on the vibrator, once you enable SmartProfiles, the vibrator will not work.
