Cant view Recurring Events from Outlook in P800
2 replies · 1,969 views · Started 08 April 2003
Hi Everyone 😃
I can sync my P800 with Outlook w/o problems, however after syncing I can't see Recurring Events from Outlook in P800. They are still visible in Outlook after syncing but it is annoying that allt birthdays etc. are not visible on the P800...
Ideas anyone?
Thanks :P
I have a similar (or same) problem... I just upgraded to the latest synch software (pc suit 1.4.2), but it didn't help. I am using Outlook 2000 and Win2k SP2 by the way.
It seems that the recurring items are synched, but differ from the Outlook items (they are not tagged as recurring?), so that if I choose to solve "changed items on both pc and p800" to "duplicate on both devices" I get duplicated items... they look alsmost the same in Outlook, but one is recurring and one is not.
I am sorry if this was confusing, but I'm not exactly sure what my problem is.. i seem to have problems with synching:
* recurring items
* items with several attendees
* other unknown (some are duplicated for no obvious reason!)
After fiddeling around for a while, ending up with lots of duplicates (they are a pain!), I have found out what settings seem to work best:
Use "Auto resolve conflicts - keep items in computer (in sync station settings->standard sync)
If you have more input on this subject please respond!
rgds,
Carl
in the synch station setting
select full synchronisation and select merge items on phone and PC
one thing i have noticed is that it didnt sync the first time so what i did i removed the recurrance on the outlook then synched and later i added the recurrance and it worked!
how? no idea ,, it might be a glitch
then syncronise and see.
G'luck
