Hi
anyone got some settings that works perfect for the phone??
i personally use this:
Resolution:
174x144
bitrate 128kbs VBR
audio 6,7 3gpp
iframe 1 every 10 sec
and between 7,5/10 fps, but if i put it higher the video begins to stutter when i play it on the phone:,( and lower bitrates are kinda ugly
just downloaded pvauthor today, so i don't have any favorit settings, but i will try yours... Thanks...
Ps. How do you watch the movies from mmc? wich app
yes from mmc using realplayer, works fine
are these the settints u use when converting video so tht it works on phone yea
realplayer doesn't support mp4, so i still have my problem loading the videos from mmc.
Yes it does, but you have to select the correct audio codec for it to work, select gsm 3gpp sound, instead of the standard
