N79 FM Radio
1 replies · 19,078 views · Started 07 February 2013
I
I have acquired an n79 in very good condition & with only 15 hours on the life timer.
All seems to work OK apart from the FM radio (receiver) which I cannot make work,
If I select visual radio with the headset connected, then try to tune, the tuning symbols just goes round constantly.
I have an n85 which works ok so I know what should happen.
FM transmitter works OK, and I have reinstalled the phone software.
I have also seen the same on another N79 which I had for a while.
I have found other similar posts but with no real answer.
Is this a problem with the model?
Can anyone help?
I have my friend who has same problem like that with his Nokia N97 handset and he instantly visit to the Nokia care. They just solve his problem in 2 days and his FM radio gonna work very easily. So, I will refer you that just visit Nokia care and explain your problem with handset.
