Does anyone know how to configure the SE p800 WAP settings for Rogers AT&T network in Canada?
These are the settings that I have but still don't work:
INTERNET ACCOUNT SETTINGS
Account Name: Rogers WAP
Connection Type: GPRS
User Name: wapuser1
Password: wap
Get IP Address Automatically: Checked
Get DNS Address Automatically: Checked
Use Proxy Server: Unchecked
Enable PPP Extensions: Checked
Authentication: Normal
WAP ACCOUNT SETTINGS
internet Account: Rogers WAP (with above settings)
Use Proxy: Checked
Address: 208.200.067.150
Port: 9203
Username: wapuser1
Password: wap
I've been struggling with this for 2 months now. If anyone can help me out, I will be very very grateful. Thanks.
your settings look ok.
i mistakenly got the wireless internet plan when i got my phone activated. But when I switched it to the data access plan, then i was able to surf the internet.
my gprs settings are:
username: wapuser1
password: wap
address: internet.com
all other settings are left at default.
You guys seems to know what you're doing.
Would you by any chance have the settings for the Nokia 6600. I tried what you posted, and I can establish a connection, but when I try to go to a site, it says something about a bad gateway?
Please help, I dished out a few pennies for this phone and I'd like to be able to use it online.
Thanks,
Milo
I'm having same problem as Pool_junkie!
My browser either says "timeout" or says "bad gateway"
Somebody help please because when i called nokia service center the lady seems to know nothing and was just wasting my time sitting in tech support just for the name of it.
-Ajay
I was having issues, and i searched the web for the settings, i did find some settings that worked, however the site was slow, and software i was using to synce Google Calendar to my Mobile through goosync . com kept timing out. I finnally found settings that do not time out and still allow me to get online. Thought i would share them. These are for my K790a but it should work for K800 and k790 models forsure
Menu >> Connectivity >> Data Communications >> Data Accounts >> New Account >> PS data >> My Rogers Data (Give it whatever you want for a name)
[INDENT]
APN: goam.com
Username: wapuser1
Password: wap[/INDENT]
(Now you have to save it and then when it goes back to Data accounts, select the one we just made and click edit)
[INDENT]Login Request: off
Allow Calls: Automatic
IP Address: ...
DNS Address: 207.181.101. 4
Authentication: PAP (Check Marked)
Data Compression: OFF
Header Compr: OFF [/INDENT]
Now we have to create the Internet Profile
Menu >> Connectivity >> Internet Settings >> Internet Profiles >> New
Name: My Rogers Net (Give it whatever you want for a name)
Connect Using: My Rogers Data (The data account we just made)
(Now you have to save it and then when it goes back to Internet Profiles, select the one we just made and click More >> Settings)
[INDENT]
Use Proxy: Yes
Proxy Address: 010.128.001.069
Port Number: 80
Username: wapuser1
Password: wap
(Save Settings)[/INDENT]
And lastly we need to change the Home Page
From the Internet Profiles Page, select the profile we just made (My Rogers Net) >> More >> Advanced >> Change homepage
[INDENT]
Name: Rogers Home (Name it whatever you want)
Address: http :// mymobilehomepage.rogers . com[/INDENT]
So i started having some troubles with the config i poisted a while ago. My syncing stopped working, the main things i changed were my internet plan. I was using more data. So i upgraded to the $19.99 package. Anyways this is beside the point, i was poking around online and i found that it seems the APN changes once you switch packages, (notsure if this is correct). The new settings also seem Alot Faster
Change the APN from ' goam.com ' to ' internet.com '
Also remove the proxy portion.
The settings should look like this if you have an internet Plan
APN: internet.com
Username: wapuser1
Password: wap
Login Request: off
IP Address: ...
Header Compr: OFF
Use Proxy: no
Username: wapuser1
Password: wap
(Save Settings)
