Hi all,
Question: do you get an mpg, mpeg, 3gp, 3ggp, dat File on the Email Acount for the Videofile ??? I mean which in format it will be stored.
thanks
Hi all,
thanks
If you use the video recorder from Nokia's site, then the files are in the 3GPP standard format (.3gp).
can anyone send me a small Video with the Recorder from Nokia to the following Email: [email protected]
Or does anyone have an idea why i�m getting a DAT File instead of 3gp.
PS: after renaming the File I can play it on my pc
thanks
Can I send a recorded video through the phone to Email through mms??
Yes, if your operators MMS center allows it.
_Gizmo_
You probably have a 7650 version 3.16 or earlier. It is a bug in the SMTP headers that was fixed later (4.39 and on).
