some questions
1 replies · 1,549 views · Started 10 August 2002
1. How to save contacts to sim
2. Where download firmware
3. It is possibile with IR manage the smartphone as a win-disk?
4. I have problems with callerIDentification: in same case, the phone don't
show the name of the caller. i.e. for call not from cellular (I have 500
contacts...)
5. How can I delete all item from calendar?
Gianluca, Italy
Nokia7650 V3.12
Hi G. ...
I am italian too but i will write in english for the other peoples.
1. I'll find only one way to save the contacts to the sim ... open the contact and then Options -- Save to sim. If the name and surname is empty, the menu doesn't appears.
2. If you find a new firmware .... please advertise me .... :roll: I have problems with a TIM branded phone and 3 link's in the Favourites that i cannot delete ...
3. I dont know
4. Some fixed phones, are as protected numbers, so the number doesn't appears... by the way i dont know what happens if you have 2 contacts with different names but the same number .... check it.
5. I think the only way is to restore the phone with factory settings.
Ciao,
