Has any of you tried installing the msn messenger for 3650? What connection does it use? Internet APN or WAP APN?
MSN messenger on 3650
That would depend on your operator and the settings and access points they sent you. I use my GPRS AP for wIrc, IM+ etc for one operator, the other one just supports WAP gateways, and hence I can't use those applications.
If your operator doesn't allow free GPRS usage (ie only WAP/Email/MMS nothing else) I would consider changing it.
i suppse this costs right jus like wap browsing owuld or something?
Ok thanks! I'll try the app and see for myself 😊
