Having brought my phone two weeks ago this website has been of fantastic help, so keep up the good work guys!! 😊
Now for the silly question what is the memory stick duo used for (The one that does not fit into the phone)??
Also is the 64 meg memory stick for sale on dabs the one that fits straight into the phone?
Very kind regards
Nick 😃
That's the adaptor for normal Memory Stick slots. And yes, the 64 is for sale, next week even the 128 will be available
Adaptor for what??? Soooo confused..
Also why is the memory stick called a duo?? So many questions!!
Well there is the normal Memory Stick (the length of the adaptor) and the Memory Stick Duo (the small card, that fits into the P800).
Now, if you want to use the small Memory Stick Duo card in a device with a normal Memory Stick, you can use the adaptor...
Hope that clears it up for you
cheers guys much appreciated 😊 😊 😊
all in the faq and the p800 user manual.
