Hi is there anyone out there with a TDK Bluetooth USB adaptor? Im having trouble sending messages from my pc to the phone. I think this is done through the 'TDK Mobile' software included but I can't conct to the phone with that. ("Connection to the phone has been lost please try to reconnect"😉
I have everything else working just cant send messages. What i need to do is send a .zip file to my 7650 Inbox. Any ideas anyone?
TDK Bluetooth Messaging?
I don't use the TDK adapter, but all I have to do is pair the computer and phone using the software that came with the adapter (and phone) and then right click on the file I wish to send and send to the bluetooth device I want.
If you havn't already done so, do a search of the forum, as one of the most asked about problems are BT ones.
Bob
P.S. Welcome to the forum
Hi, I've got a tdk bluetooth adaptor.
To send files, I mearly right click, and use the send to: bluetooth -> 7650 option. Or use my bluetooth places. The actual TDK Mobile software that allows sync between phonebook and pc isn't 7650 compatible yet (iirc its pants anyhow)
Hope this helps.
Flubster
