Java MSN
3 replies · 1,667 views · Started 09 April 2003
OK i tried Searching...
I have trouble connecting... Installing is easy but i feel something is missing...
Is there something else i must do ? i installed Jmsn .. and tried to connect...
Got a Kernel error
[quote="Muzikfreakah"]Try Using 12planet IM man. Its the Best MSN applet for te P800.[/quote]
I agree. But I got one problem with it. You won't get ANY notification when receive a message! Is it just me, or does everyone have the same problem?!?
[quote="Delta737"][quote="Muzikfreakah"]Try Using 12planet IM man. Its the Best MSN applet for te P800.[/quote]
I agree. But I got one problem with it. You won't get ANY notification when receive a message! Is it just me, or does everyone have the same problem?!?[/quote]
Everyone has the same problem 😊 I hope they can add that though, but since Im using the trial which I dont what the difference is from the pro(or non trial) and its free, I dont really mind 😊
