I am having huge problems syncing my P800 with Lotus notes. It will sync email but not calendar or contacts.
Does anyone know if there is any other software that will work.
ps It can't be server software, we are not set up for that yet.
probably somebody should take some time to write one.
Just wanted to let people know that once I was issued with a new Lotus notes ID the problem disappeared.
Syncing worked fine first time just using the default settings.
Michaelr, does it sync with Lotus Notes 6?
bluephone, we use Lotus Notes 4 and 5 here. I have been told by SE support in Australia that it does not support 6.
bluephone,
Here is a registry hack the let's the Sony Ericsson sync software think your Notes 6 databases are Notes 5. You can then sync your phone. Unfortunately, the sync doesn't work for all Notes users. In my case, I sync Contacts and To Do's fine, but Calendar entries don't sync at all. I'm using XTNDConnect PC to sync my Notes 6 Calendar with Lotus Organizer 6 and then go from Organizer 6 to my P800. It's pretty clumsy, but it works fine.
http://www-10.lotus.com/ldd/nd6forum.nsf/DateAllThreadedweb/95629f3e193f009b85256cc6005aa8d8?OpenDocument
