Running system applications from C++
1 replies · 2,156 views · Started 10 April 2003
I want to run some of the system applications (e.g. Viewer, Video etc) from a C++ library on the P800. Is this possible?
The behaviour I want to achieve is as follows:
- Java class passes a file name (e.g. jpeg filename) to C++ library via JNI
- C++ library loads appropriate application (in this case, the ImageApp) supplying the filename as specified from Java
I've tried it from Java without JNI, using the following call:
Runtime.exec("Z:\\System\\Programs\\AppRun.exe Z:\\System\\Apps\\ImageApp\\ImageApp.app C:\\documents\\Media files\\image\\unfiled\\Purple.jpg"😉;
This launches the ImageApp application, but doesn't display the specified jpg file. Can I do this with C++?
thanks,
Derek
