A NEW FOX HOUND ORIGINAL :D
28 replies · 3,526 views · Started 10 April 2003
can i request a wav file? incomplete by sisqo and gossip folks by missy elliot ..tnx! just cut a short portion of the song like the ones you did here! tnx a lot!
[quote="FOX HOUND"]it's been sometime since i posted something like this
have fun 8)[/quote]
Thanks 😃 I've been looking for it for ages
[quote="ST@RR"]I have some incubus ring tone here... echo and are you in 😊[/quote]
Thanks st@rr. Nice avatar too :P
has anyone played around with optimum settings for wave files? whats the general best sample rate to use? i was thinkin 22khz mono 8bit would probably sound no different to anything higher and keep filesizes down, but i haven't got my bluetooth adapter yet...
im searching thru all of my cds to find loopable tracks. when i've done some, i'll test em on the fone to make sure they loop properly (with wavs it doesn't add a gap to the end does it? that'd suck if it did ) and then i'll make a grabpack of stuff.
it'll mainly be dance tracks old and new, along with some nice guitar riffs from my punk/hardcore cds. nice mixture :>
[quote="ST@RR"]Hmm... I'm using GSM coding and 22khz of frequency.[/quote]
or you can try "IMA ADPCM" coding and 22khz mono it has better quality on the phone and the Compression ratio is not bad 8)
try my new one
Thanx for the tip on compressing wav with ima adpcm. that
decreased the size of my tune a great deal 😃
hope u dont mind me posting my first wavs, and hoping someone
could give me an opinion and improvements to make better
loops.(better sound quality,sizes....etc)
this is my first attempt on attachments so -bear- with me 😃
gee Thanx...... guess i found myself a new hobby 😊
(,,,want more ?... 😊 )
-snip jayX-
-snip-
nope - doesnt sem to add any gap at the end , when i make a wav-loop
with cool edit - its pretty much finished work, and sounds ok on the 7650😊
( i think the p800 makes a gap at the end of the file doesnt it ??
.. but then again the phone has lots of mem (so that wouldnt be an issue)
I would believe that p800-owners do not want such loops huh? )
how is the soundforge vs cool edit ? anyone ?
(havent tried sound forge) 😃
