I got this app called breadbox. It comes with the phone and wants to install or my mmc. I however have purchased a 128 mb mmc and want to put it on there. How can i make it so the phone saves to the internal memory instead of the mmc?
Breadbox?
I was able to get breadbox to the new MMC by doing a backup of the old MMC using the PC Suite and then restoring the backup onto the new MMC. You will not find the Breadbox application if you slap in a new MMC since the app is installed on the manufacturer MMC.
yeah. Transfer the files in the old MMC to the new one. You can just transfer it immediately if you have an MMC reader/writer device.
Can I ask what Breadbox is?
Breadbox is an application found on the Nokia 3650 here in the US. It contains various applications and games all on a trial period basis. Once you have exhausted all trials then you have the option of purchasing it.
Here are some of the apps found in Breadbox: (Acutal apps and games contained on the MMC may vary)
Imaging: Exego,PhotoBase,FotoFunPack
Games: CellPoker,Popstar,Geopod,Mobile VR Pool,Spygirl,MP3Go,Cellhalma,Steel Warrior,Active Toons
Tools: AvantGo,Handy Shopper,Handy Clock
cool~ whats avantgo? sounds familiar.. like the name of something from phpnuke a while ago.
[quote="ST@RR"]yeah. Transfer the files in the old MMC to the new one. You can just transfer it immediately if you have an MMC reader/writer device.[/quote]
Are you sure?
What I found is that Windows can see only Image and some Sound file. Windows can't see program file.
Can you advice me how to copy all files from old MMC to new MMC without using Nokia suite (backup/restore)?
how long are the trails for?
if only breadbox is aavailable in 3650s in malaysia
[quote="Seremify"]cool~ whats avantgo? sounds familiar..[/quote]
