Hi i just bought used nokia n80 and i have 1 problem..
My phone crashes in the middle of me using it, mostly when i am talking or when i try to send a msg..
then the nokia white screen apears and the rest works the same as it restarted but without the 2 hands shaking animation.
i dont know what to,i gave it to a man to flash the software and he says he did is and it didnt stop so if you know what to do i would be verry thankful..if no one of you knows how to fix it then tell me how to flash it to an old version of the softwere maybie that will fix it..
sorry for my bad english as it is not my native language..
Cheers
