Just wonderin.. I've come to realise that my 3650 runs out of memory alot and I hear there are progams which can help free up memory and also compress memory as well as the data..
I think I need a defragger since.. well I am constantly installing and uninstalling crap on my phone and over time its become very very slow to use.
Any advice guys? Also note i'm on a 3650 (hence why I post here).
jeff.
I suggest that you install Appman or Task Manager which free up the real-time memory especially if you noticed some kind of 'slow' in using your phone.
Another application that is useful is File Manager from psiLOC, which cleans up the temporary folders. This is useful if you frequently install/uninstall applications. Some softwares are leaving 'tidbits' in our phone though it has been removed. File Manager will clean it.
Stacker or Space Doubler is another good applications in compacting the contacts.
I did not compressed any application todate using Stacker because I still have more than enough space though there are 54 apps installed in the MMC and 1 in the phones' memory (previously 2). I will compress them if I have to.... but not necessary this time because I don't experience slow in using 3650 as of todate.
:angel:
how much memory do u hav?
i'm still finding Doom to not run (not enough memory).. any ideas guys? even with Appman compressed memory to 2.7meg it still won't run!!!
