hello..
how come i cant view the pics taken from my handy cam on my p800,
i know a file have been saved coz the amount left when i check the duo
was lower than it used to be, and is the video taken by the handy cam
are saved on mp4 format??
thanks.....
Have you made sure that the files are in an area the P800 can see?
When you format a Memory Stick Duo on the P800, it creates a folder in
the root of the drive. The p800 will then only see files in this folder.
I assume the handycam does the same. So, when you record something
on the handycam, you would need to move it from the handcam's folder,
into the media folder for the p800 to see it.
e.g.
d:\handycam\video\myvideo.mp4
to
d:\p800\media files\video\myvideo.mp4
You should be able to do this with a standard memory stick reader on a PC using the Memory Stick adaptor that came with the MS Duo.
