System error!
20 replies · 9,953 views · Started 11 April 2003
After installing and deleting some games I'm getting a "System error!". When my phone starts up, I get 4 errors and a "System error!", but my phone starts up. But after that, when I start a program I again get a "System error!". That also happens with opening the menu. When I push OK everything works fine. But I'm getting crazy with all those errors.
Are there more people with those errors?
Greetz.
Ok open your filemanager (on your phone (DOH!))
Then delete the file C:\system\System.ini
Then delete this file C:\system\fep\wildskin.ini (or similar)
Then restart your phone. You will experience a system error during startup but this is normal as the phone is looking for the system.ini but its not there.But dont worry as the phone creats a new system.ini which contains no wildskinz files.
(hope you understand)
I understand. I had found the system.ini already, but didn't dare to delete it then. Now I'm deleting it. Starting up the phone. Not getting errors. I'm a very happy person.
Thank you a thousand times. You're the man!
Greetz.
Hey guys... I had a similar problem with the "System Error" appearing during startup. I had never installed wildskins, so I couldn't delete that. I did try deleting the system.ini file, but that didn't seem to help. Also tried booting is safe mode, and also without the MMC in place. No dice. Finally I just started deleting apps... Once I deleted all of the PSIloc apps, the error went away. Now I'll try putting apps back on and see if I can pinpoint the issue. Hope that helps..
Greetz.[/QUOTE]
i get the same error only with goboy emulator ,any one able to help what is happining?? thx
Guys, thanks so much for posting your experiences with the "system error". Sure enough, I had installed WildSkinz and later uninstalled it, after which I got all the same "system error" messages, and no longer could type text. I spent several hours last night trying to backup, restore, etc. all to no avail. Deleting the system.ini file worked perfectly. Such a simple solution. Again, THANK YOU.
you all saved my ass cheers, that delete system.ini really works.
sir, i get a system error when saving setting for mms to my phone n3650, what shall i do?
thanx man!!!!!i dont kno how to say thank you!!!!ur d best!!!
Hello everybody!
I'm having the same problem, but after i deleted (several times) System.ini (there was no wildskins.ini - maybe i deleted it after uninstalling) there is no difference: i get teh same error message and i still CAN NOT WRITE LETTERS! Please help me!10x:redface: :redface: :redface:
Do not just uninstall WildSkinz without disabling it first. If you did, reinstall WildSkinz and then disable it, reboot and uninstall only after that.
Unregi wrote:After installing and deleting some games I'm getting a "System error!". When my phone starts up, I get 4 errors and a "System error!", but my phone starts up. But after that, when I start a program I again get a "System error!". That also happens with opening the menu. When I push OK everything works fine. But I'm getting crazy with all those errors.
Greetz.
[/QUOTE]
Hi there,
i encounterd the same problem with my N6630. I couldnt actually find the system.ini file !!!!!!!!! Could u guide me through that and i also cant get to use the gprs on my fone ..... when i press and hold the 0 button the fone tries to connect but then nothing happens. someone please help.
