why does mp3go not recognize my mp3 tracks?
17 replies · 3,983 views · Started 11 April 2003
i downloaded some tracks from the net and bluetoothed them to the phone and it was stored in the playlist. When I opened mp3go, the program says file format not supporteed although the tracks were encoded at 128kbps and plays on my PC and ipod...any1 pls?
[quote="JyriK"]Are you sure those are not VBR (variable bit rate) coded?
MP3Go cant play VBR mp3's.[/quote]
nope dead sure they are CBR 128kbps
If you havent already bought the Mp3Go, try Mp3Player 1.20 from:
http://www.vikinggames.hu/
I think it is much better.
Features:
- plays MP3 files (MPEG-1/2/2.5, ABR, VBR);
- playlist (selected files/directories or all MP3 files on device);
- displays bitrate, frequency and mono/stereo;
- volume control;
- displays ID3v1 tags;
- displays time elapsed and the length of the track;
- associated to .MP3 files;
- preferences are saved.
I noticed that the sound volume is not that loud... I adjusted the volume already on the phone and it' still not loud. Is this really like this?
i had that problem too, what you have to do is go to playlist option and search for the folder that the mp3s are in. It should work then.
Ok! But i think it's because my mp3 is stereo and our phone is mono 😊 I'll try to see if my headset is stereo 😊 But thanks!
[quote="Frenchie746"]i had that problem too, what you have to do is go to playlist option and search for the folder that the mp3s are in. It should work then.[/quote]
nope when i selected the + songs icon, it shows my C:\ and E:\ directories but nothing was found.
found the problem. when installed mp3go, it created an mp3 folder which saved all the mp3 tracks there but somehow the program cant detect these songs in the folder, so i moved them to the root directory and so it worked!
How can i save my mp3 files that i beamed from my PC using bluetooth? I cannot open the file in the inbox folder nor can i move it to another folder? Please help!
Ah, you're using PC suite? Anyway, I just tested this mp3go app and I sent an mp3 file to my cellphone using bluetooth... and the file cannot be open in the message inbox nor it can be saved. Anyway, forget about this 😊 I'll just use the PC Suite to transfer mp3s to my phone. THanks! 😊
[quote="ST@RR"]How can i save my mp3 files that i beamed from my PC using bluetooth? I cannot open the file in the inbox folder nor can i move it to another folder? Please help![/quote]
just install "SeleQ". It help alot...thats program as like as your PC. u can move or create dir where u like...
