VPN, Camcorder, miniGPS on P800
8 replies · 3,318 views · Started 11 April 2003
Hi all !
Is it possible to syncronise remotely email and calender over VPN ?
Would it be possible to have camcorder on P800 ?
Where can if find miniGPS beta ?
Guest
:fadein: :roll:
Don't know, No. Search and you will find, it is out there and there is a threat on it. You just have to do a little homework, that's all
[quote="Me"]Don't know, No. Search and you will find, it is out there and there is a threat on it. You just have to do a little homework, that's all[/quote]
My message has 3 questions !
and you got 3 answers
it is possible to make a camcorder app, but there isn't yet any out either we don't know if anyone is developing it now
you can't find minigps, because it is a closed beta test and not for everyone. if you still wonna try it, ask psint (www.psiloc.com)
Anyone tested the Hantro 3.3 for Nokia 7650 for the P800 guess it would work as it is the same Symbian OS???
Anyone tried it yet???
[quote="beta3"]and you got 3 answers
it is possible to make a camcorder app, but there isn't yet any out either wo don't know if anyone is developing it now
you can't find minigps, because it is a closed beta test and not for everyone. if you still wonna try it, ask psint (www.psiloc.com)[/quote]
Thanks,
I think i finally found the answer myself just look the links:
http://www.psionplace.com/articles/2003/3/2003-3-17-Certicom-to-Develop.html
http://www.certicom.com/
It would be nice to know if they could also be a solution for FAX !
[quote="Guest"]Hi all !
Guest
:fadein: :roll:[/quote]
For your first question, Yes. I've sync with my Lotus Notes via VPN at home.
[quote="dakl2000"][quote="Guest"]Hi all !
Guest
For your first question, Yes. I've sync with my Lotus Notes via VPN at home.[/quote]
Do you have a VPN client for the P800? Where can I get this?
[quote="crypto"]Anyone tested the Hantro 3.3 for Nokia 7650 for the P800 guess it would work as it is the same Symbian OS???
Anyone tried it yet???[/quote]
whoa, you'll have incompatibale sis installer file error, the p800 is uiq (7.0) whereas the the 7650 is ui symb 6
