I got a P800 but i dont know how to transfer songs or pictures from my PC to my p800.Everytime i go to the option install software a image comes up which shows the tranfer but at the end i get a message request not supported.Please help me.
how to download songs or pics on a p800
[quote="pranayambwani"]I got a P800 but i dont know how to transfer songs or pictures from my PC to my p800.Everytime i go to the option install software a image comes up which shows the tranfer but at the end i get a message request not supported.Please help me.[/quote]
You just drag and drop the file onto the phone and they will go to the appropriate folders.
[quote="Anonymous"][quote="pranayambwani"]I got a P800 but i dont know how to transfer songs or pictures from my PC to my p800.Everytime i go to the option install software a image comes up which shows the tranfer but at the end i get a message request not supported.Please help me.[/quote]
You just drag and drop the file onto the phone and they will go to the appropriate folders.[/quote]
More to the point, you do not 'install' music or pictures as they are data files. Only thing the installer will do is '.sis' files.
As noted above, you need to use explorer to drag (or copy & paste) files into the "my P800" namespace.
JulesG wrote:More to the point, you do not 'install' music or pictures as they are data files. Only thing the installer will do is '.sis' files.
im trying to download songz but u cannot do it, how do i make da file .sis coz i cant listen to it do i need to download mp3 songz if so wot website do i need to go to and what type of format do i save the file under
wot u mean by .[/QUOTE]
what does dat do
JulesG is saying that you DON'T have to convert songs to .sis. You can just open "my P800" on your computer and put the songs in the Audio folder. There is a music player built in your P800. I don't exactly know if this is the answer to your question but I hope it helped.
