who can write programs
3 replies · 2,569 views · Started 13 April 2003
i have been looking all over for some symbian software that when installed will let me add names so i can block them from ringing me with no luck.
i have no idea how hard it is to write a program but if there are some people on here that can write programs sis or java is it posible to write a small program like i mentioned . this option is available on some ericson phones and would be quite usefull ?
cheers
I think that all the program could do is just hang off. But you can do that by hand...no nood for software. I just dont see another way of blocking an incomming call!
[quote="Anonymous"]i have been looking all over for some symbian software that when installed will let me add names so i can block them from ringing me with no luck.
cheers[/quote]
maybe you can just assign a silent ringtone for the specific name.
or you can ask your network to block the number for you, it possible.
[quote="MaleBuffy"]I think that all the program could do is just hang off. But you can do that by hand...no nood for software. I just dont see another way of blocking an incomming call![/quote]
Yeah, that's the only way I can think of too...
Either have it reject the call so it goes to voicemail or whatever, or accept the call for a second and hang up, or finally play a recorded message "The person you have called has blocked you 😃."
Cheers
