Hello there. I am really a newb when it comes to the Symbian OS, and therefor am at somewhat of a loss on how to install EMAME from yipton.net. I understand how to install the .SIS (thankfully), but his instructions say to also unzip multiple source codes, as well as "updates" to those source codes. I have no idea how to do this, and would be ultimately appreciative of a step-by-step guide on how to install this on my P800. Thank you so much, in advance, for all your help.
Another EMAME question
The source code is only if you want to make modifications to the program yourself. I suspect this is pretty unlikely unless you are a 'code guru' like Mr Yipton!
Therefore all you need to do is install EMAME, download roms, stick 'em in the roms folder and away you go!
