Basically im gonna be transfering files over 30 megs. This is clearly larger then the 4 mb space built in the phone. How can I make the mmc the default memory?
Can I make my phone save to my mmc?
Best to use PC File Manager @ http://nokia-3650-software.epocware.com/
Allows you to transfer files over to mmc
If that was my problem great but I cant get the file over to the phone cuz its way too big to fit on the 4mb internal memory. I need it to save directly to the mmc and not the phone mem.
:fadein:
u sure that doesn't work?
if not then what you need is PC Suite. Make a folder on your phone's MMC (via a filemanager or even through the images program).. mine is "fun"..
then open up pc suite and the folder "fun" should appear under your MMC.. then just drag the file from your PC to the "fun" folder on the MMC and it'll copy (can take a while though).
right but im having probs with my pc suite as you cansee from my other threads.
Try looking at your setting in messages, camera, voice recorder, video recorder. You should find an option on what memory to use. Just set them all to MMC 😊 This is what I did...
