Help!
I can't delete a file without a file name.
I was trying to copy an excel file using cable, since the file is 3.9 MB it'll take forever so I bought usb card reader and start copying but the phone creates a new file without a file name, (it's only 1 byte, but it seems annoying) when I try to delete it, it says
"invalid characters"
Anybody can help me, pleaze, pleaze!
Gracias!!
Help Deleting File
delete it using USB Card reader.
Or rename-it
A file explorer can do it. Just di it 😉
pc suite is your best chance ...
Last time I had this I had to format the drive to restore the filesystem ...
delete it using USB Card reader.Or rename-it
No, can't do.
I've tried to rename it, move it using the card reader and the file manager.
Well, it looks like i have to format the card. (I'm just 2 lazy to format the card)
Thanx though
Once the filesystem is fucked up it get's rather hopeless :s
