Send Via Infra
4 replies · 1,848 views · Started 14 April 2003
Have anyone tried sending picture or watever to another phone (e.g. 6610) via infra?
the 3650 seem to have problem connecting with othe phone via infra
[quote="Anonymous"]Have anyone tried sending picture or watever to another phone (e.g. 6610) via infra?
the 3650 seem to have problem connecting with othe phone via infra[/quote]
It is very easy.....
First copy images, midis from your 3650 to your PC
then install Pc suite 5(for 6610 & 7210)...
run image converter.....
open your saved image....
cut what you want from that picture and then upload it to your 6610 or 7210
with midi there is a small problem
you have to run midi converter
check all channels
and then you must choose the 4 organs, channels (i can't explain it) that you want to hear......
drag to the top the channels you want to hear and then give them the number of the channel you want to hear it......
example
bass1 1
bass2 1
piano1 2
claps 3
synth 4 --when this channel don't play it will play the next with 4
synth2 4
synth3 4
ok????
I hope you understand, because my english is like shit
You cannot send pictures or tones to phones like 6610, 7210, 7250, 6100 using infrared. I've tried it. You have to go through all that stuff GPS said.
i have the same problem, watching replies...
hey man, lets help us ha? 😞
