converting asf,wmv,real to mpeg
3 replies · 3,020 views · Started 02 June 2002
It's illegal to make a program that can convert asf/wmv into anything User posted image Microsoft made it so. VirtuaDub for example had to remove support for asf convertion in his latest release. Some programs however "forgot" to mention that they could convert asf to avi/mpg.
This program will enable you to convert asf/wmv/avi into avi/mpg TMPGEnc
The
To convert rm to avi check this site out http//www.divx-digest.com/articles/rm2avi.html
If above program doesn't work (I'm shure it does work) you can try http//www.divx-digest.com/articles/asf2avi.html
I have a movie which plays on my desktop in real one player, but if i transfer it (1.4 meg) it says clip not playable.
I've tried using virtual dub and another prog called Tinra005 to convert the format but i lose the picture, sound stays perfect but no image. Even If uncompressed ( 114 meg!!) i still lose the picture.
Is it possible to alter the sampling rates of the two versions 'cos they dont quite match (9.36-9.60)fps. Or are the sampling rates fixed?
Any help gratefully accepted.
B.T.W. Dazler. The little problem i had with the reg. files could only be solved by creating a new profile on PC and starting the whole registry process from scratch. It still fails to connect on the old settings but it's perfect on the new ones.
Thanks anyway.<font size=-1>[ This Message was edited by hazy1uk on 2002-06-18 1104 ]</font>
