new WIFI update for 808
1 replies · 6,159 views · Started 17 April 2013
just had an update showing new wifi update and youtube integration
i noticed after installation of the new wifi update, in settings where usually you would have had one option: "enable/disable power saving" - there is now a new ADDITIONAL entry called enable/disable advanced power saving, which incidentally after the update it defaults to turning on (the advanced on) wonder what in practise thats actually doing
