Do you connect the P800 to MSN
6 replies · 2,105 views · Started 15 April 2003
I have tested the client of www.12planet.com there is intuitive interface, the same as the XP Messenger!
Yeah, it's great, although I personally feel that JavaMSN is even better, because it gives you sound notifications when you get a message
Installed it and within 30 secs was chatting away, unlike the client I had for my 7650 which took nearly a day to configure with a new gprs connection. 12PlanetIM just worked with the current connection on the phone, no messing or fiddling, just log in and chat, and I can use emoticons as well!! 😃 8) :P
I download the new version from http://www.12planet.com, it now comes with sound. What's also good with 12Planet IM is it has true emoticons while JavaMSN does only allow you to send icons but cannot display them which sucks!
i cannot connect to any MSN software.
Could there be a difference in the GPRS connection that the company gives you.
i have ORANGE & they charge us RS.250per month but do not let us connect to the computer whereas BPL(another company) charges Rs750 per month & lets you connect to teh computer as well.
Can anyone help me with the pics below.
Thanks a Ton.
[quote="Delta737"]Yeah, it's great, although I personally feel that JavaMSN is even better, because it gives you sound notifications when you get a message[/quote]
can u give me a link for this application? Im a 9210 user, thanks
[quote="jojo"][quote="Delta737"]Yeah, it's great, although I personally feel that JavaMSN is even better, because it gives you sound notifications when you get a message[/quote]
can u give me a link for this application? Im a 9210 user, thanks[/quote]
I could (you can find it at My-Symbian.com) but, although the name is JavaMSN it's not a real Java app. It's a .sis file, specifically made for the P800, so that won't work on your 9210
