Hi
Has anyone developed a query tool for SQL Server yet?
SQL Query Tool
Use VCD to connect to your desktop, then use SQL Query Analyser on that; you really do not want to do a
select * from myVeryBigTable
over a GPRS connection!
Correct, but no dba would do select * from myVeryBigTable.
But i would like to query a table or run an SP or insert, update etc.
By VCD do you mean VNC? I've tried this over dialup 9600 on the P800. it's too slow, i might as well drive to work.
Thanks anyway
