Problem with PC Suite 1.1.0 for Nokia 7650
1 replies · 1,665 views · Started 16 April 2003
Hi, I lost my Nokia 7650 couple days ago :cry: Fortunately I already backed up my contacts with PC Suite 😃 The question is, how do I look at my backed up contacts in PC Suite ? They said that I can work offline with it.
Who said you could work offline with it??
If you look in the backup directory on your PC, there are loads of .dat files. If you check the index, you will see which .dat file refers to the contacts, but I wouldn't try editing that. If you screw it up, your backup will not complete... safer to modify on the phone.
On this forum there has been some threads on 3rd party software (Oxygen Phone Manager for example), but I don't know if they work for the 7650). Do a search on the forum.
Paul
