Hi y'all,
Does anyone know how to transfer the SMS-messages from my 7650 to a desktop PC?
My desktop-PC runs under Win XP, and I have a Trust BlueTooth stick.
Are there any specific apps. I have to install??
Thx!
Zmurph
Amsterdam, The Netherlands
Hi y'all,
Thx!
Zmurph
You may want to install Message Saver, marked all the incoming SMS and sent to your email (auto convert to txt format). This is one of the solution I can help you to think of.
Anyway that's the way how i archive all my sms messages.
OK, sounds good. Now I only have to setup email 😉
Guess I have to do that, first... 😉
[quote="Edgedale"]...sent to your email (auto convert to txt format).[/quote]
Thx!
u can copy the sms messages via the abc key while in edit mode (via forwarding it or sumthin) and paste it on the notes program on the phone. then u can send it via bluetooth or whatever... 😃
I think that Message Saver works fine but it would be grate something that could syncronize and overwrite already saved messages. I don't know if there's any application like that. If you find any, please tell us.
