Hey my 3650 ringing volume is too low. I have checked the volume level is set to max but still the vol sucks.
ringer volume too low
u using a downloaded polyphonic? try using a monophonic ringtone (without a .mid on the end).. to make polyphonics louder use ringtone studio from wildpalm.
Hi.. even I just the Ringtone studio and adjust the ringtone to 200 %... but still, I don't hear any different... so the best way is to use back the old ringtone, altho' they don't sounds well.. but they sounds LOUD.. is that what u want, Right?? 😊 😊 😊 😊 😊 😊 😊
Its a known bug my friend.At the beginning my phone was ok..only 1 time in 20 the volume was low!.now its the reverse.1 time is ringing loud.The only way to solve this temporarly is to put the wav tone u want into the general profil but also activate VIBRATION!Then call your mobile...and u will hear the difference.Deactivate the vibration and the volume will still be high.Only probleM??..doesnt last long...
[quote="PhoneMan"]Hi.. even I just the Ringtone studio and adjust the ringtone to 200 %... but still, I don't hear any different... so the best way is to use back the old ringtone, altho' they don't sounds well.. but they sounds LOUD.. is that what u want, Right?? 😊 😊 😊 😊 😊 😊 😊[/quote]
i personally created a profile called LOUD where it uses monophonic ringtones.. but phoneman - try duplicating the instruments u WANT and setting them to volume 200; and if still not loud enough keep duplicating.. and even try changing to louder instruments like string instruments. i've noticed that the piano is VERY VERY SOFT in comparison to other instruments.
