Mobile Fax for 7650
3 replies · 1,678 views · Started 16 April 2003
I've just received my registered version of MobileFax (www.bitween.com) today !! Great app !! that's what I'm waiting for a long time for my 7650 !!
(just a little bit expensive .... 25 euros !!)
Domi.
does it work on yr N7650 ?? (can you receive incoming fax??)
if yes, which firmware does yr 7650 have??
thks &rgds,
johannes
I had a problem while testing the trial. It never answered my incoming fax calls. Anyone know a solution to this problem? If it works, this is the killer app I've been waiting for..
Hello,
I'm using the registered version of Mobile Fax. It doesn't answer incoming fax-calls. What can I do to fix it? I'm using a very recent version of the firmware: V 5.06 (02-06-03). Thanks in advance.
Regards,
Roger
